TwinTurbo.NET: Nissan 300ZX forum - I have yet to read a good explanation of why lowering the
Subject I have yet to read a good explanation of why lowering the
Posted by kkrofft (OH) on July 17, 2008 at 8:16 PM
  This message has been viewed 46 times.
In Reply To posted by on {No date specified}
Message back pressure causes 300ZX turbos to leak but it is a common
source of discussion. Generally the advice is to replace the cats if the smoke is not too bad and it will often fix it.
If you replace the turbo's buy new for best chance of not having a repeat of the problem.
Be sure you do the pressure test too. It may be a bad sending unit or gauge but there could be another issue there with the high readings. I once had an engine builder tell me that excessive oil pressure could "wash" the babbit off the bearing shells.
KK
